link 2.15 with JS for dos it's out (Announce)
Ahoj Roberto,
Where You have JS enable??? 2.15 sources are without JS :(
Option in configure has not JS :(
david
> > > Where are the sources? Are they the same as vanilla 2.15? Binaries and
> > > sources (for exact same version) must both be available (GPLv2+).
> from Mikulas :
> You can get the source (including javascr***) from
> git://leontynka.twibright.com/links.git
> You can use the --enable-javascr*** parameter to ./configure to enable
> javascr***.
> I used these djgpp packages when compiling links for DOS. If you download
> them, you'll get the same build as me.
> bc106b.zip bz2106b2.zip djtzn204.zip gcc730b.zip grx249b2.zip
> jpeg9cb.zip man13br2.zip shl20112.zip txi413b2.zip xz-508a.zip
> bnu230b.zip csdpmi7b.zip ed-1142b.zip gdb72br4.zip gwk420b.zip
> lss481b.zip pcre841b.zip ssl102kb.zip txt20br2.zip xz-508b.zip
> bsh204b.zip dif36b.zip fil41br2.zip gmp612b.zip gzip18b.zip
> lzlib18a.zip png1634b.zip tar112ab.zip zlb1211b.zip
> bz2106a2.zip djdev204.zip fnd42335.zip grep29b.zip jbig21b2.zip
> mak421b.zip sed44b.zip tiff409b.zip wh220br2.zip
> the wattcp I use is wat3222br6.zip
> Previous versions of the library contained a bug that caused crashes if
> the server sent too much data, over the window advertised by the client.
- link 2.15 with JS for dos it's out - iw2evk, 28.03.2018, 12:44 (Announce)
- link 2.15 with JS for dos it's out - ron, 29.03.2018, 00:06
- link 2.15 with JS for dos it's out - Guti, 31.03.2018, 09:46
- link 2.15 with JS for dos it's out - rr, 01.04.2018, 18:00
- link 2.15 with JS for dos it's out - Rugxulo, 02.04.2018, 03:25
- link 2.15 with JS for dos it's out - iw2evk, 10.04.2018, 18:40
- link 2.15 with JS for dos it's out - Rugxulo, 10.04.2018, 23:45
- link 2.15 with JS for dos it's out - iw2evk, 13.04.2018, 17:22
- link 2.15 with JS for dos it's out - Rugxulo, 13.04.2018, 23:03
- link 2.15 with JS for dos it's out - iw2evk, 28.04.2018, 18:12
- link 2.15 with JS for dos it's out - david, 11.05.2018, 19:13
- link 2.15 with JS for dos it's out - iw2evk, 11.05.2018, 19:24
- link 2.15 with JS for dos it's out - david, 12.05.2018, 11:09
- link 2.15 with JS for dos it's out - david, 12.05.2018, 14:40
- link 2.15 with JS for dos it's out - Rugxulo, 14.05.2018, 00:04
- link 2.15 with JS for dos it's out - david, 14.05.2018, 18:03
- link 2.15 with JS for dos it's out - david, 14.05.2018, 19:50
- links 2.16 - Rugxulo, 15.05.2018, 02:46
- links 2.16 - KormaX, 22.08.2018, 22:55
- link 2.15 with JS for dos it's out - GNUser, 05.05.2018, 16:52
- link 2.15 with JS for dos it's out - Rugxulo, 06.05.2018, 05:30
- link 2.15 with JS for dos it's out - roytam, 07.05.2018, 00:33
- link 2.15 with JS for dos it's out - Rugxulo, 14.05.2018, 00:49
