DOSBox-X 0.83.7 released (Announce)
posted by Wengier E-mail, 06.11.2020, 08:20
(edited by Wengier on 06.11.2020, 09:19)
> > This version works in contrast to the previous version which ended with
> an
> > exception.
> For me partially. I have MS-DOS 7.1 based system with JEMMEX memory manager
> with EMS memory set (so system is running in V86 mode)
> If I run DOSBOX-X normaly - it runs
> But if I firstly run the SoundBlaster Live! emulation driver (via
> SBEINIT.COM) then it hangs with
> this error message
> I have set the environment variable HDPMI=512
> (not sure if it has some meaning with this build-in version of HX-DOS)
The %HDPMI% setting should have effect. But if it does not run with the SB Live! DOS driver (SBEINIT.COM) then it likely means there is still some compatibility issue between HX DOS Extender and SBEINIT.COM.
22762 Postings in 2122 Threads, 402 registered users (1 online)
