VSBHDA v1.4 (final) has been released (Announce)
> > > https://github.com/Baron-von-Riedesel/VSBHDA/releases
> > XMS restrictor(xmsres.exe) by Japheth included in Sound blaster
> emulation
> > for HDA (High Definition Audio) with
> > io8emmok.sys driver
> by
> > Dr. Pufeng Du allows you to run Windows 3.1 from MS-DOS 8.0 in 386
> Enhanced
> > Mode on real hardware.
> in MS-DOS 8, not only io8emmok, but also EMM386.EXE are required for
> running Windows 3.x correctly.
My config.sys for MS-DOS 8.00
The main thing is memory limitation
device=io8emmok.sys
device=emm386.exe noems
install=xmsres.exe 512
install=w3xstart.com
- Tyrian 2000 in DOS with sound on PCIe only machines? - Japheth, 20.03.2024, 11:46 (Announce)
- Tyrian 2000 in DOS with sound on PCIe only machines? - Rugxulo, 21.03.2024, 05:52
- Tyrian 2000 in DOS with sound on PCIe only machines? - Laaca, 21.03.2024, 18:36
- Tyrian 2000 in DOS with sound on PCIe only machines? - Japheth, 21.03.2024, 21:42
- Tyrian 2000 in DOS with sound on PCIe only machines? - Zyzzle, 23.03.2024, 02:58
- Tyrian 2000 in DOS with sound on PCIe only machines? - Japheth, 23.03.2024, 10:54
- Tyrian 2000 in DOS with sound on PCIe only machines? - Zyzzle, 24.03.2024, 02:18
- Tyrian 2000 in DOS with sound on PCIe only machines? - Japheth, 24.03.2024, 05:06
- Tyrian 2000 in DOS with sound on PCIe only machines? - Zyzzle, 25.03.2024, 22:42
- Tyrian 2000 in DOS with sound on PCIe only machines? - RayeR, 26.03.2024, 06:16
- Tyrian 2000 in DOS with sound on PCIe only machines? - Japheth, 26.03.2024, 08:34
- Tyrian 2000 in DOS with sound on PCIe only machines? - RayeR, 26.03.2024, 13:48
- Tyrian 2000 in DOS with sound on PCIe only machines? - RayeR, 27.03.2024, 02:17
- Tyrian 2000 in DOS with sound on PCIe only machines? - Japheth, 27.03.2024, 06:33
- Tyrian 2000 in DOS with sound on PCIe only machines? - RayeR, 27.03.2024, 14:06
- Tyrian 2000 in DOS with sound on PCIe only machines? - Laaca, 27.03.2024, 17:35
- Tyrian 2000 in DOS with sound on PCIe only machines? - RayeR, 28.03.2024, 04:39
- Tyrian 2000 in DOS with sound on PCIe only machines? - Zyzzle, 27.03.2024, 14:27
- Tyrian 2000 in DOS with sound on PCIe only machines? - RayeR, 27.03.2024, 16:02
- Tyrian 2000 in DOS with sound on PCIe only machines? - Japheth, 27.03.2024, 17:39
- Tyrian 2000 in DOS with sound on PCIe only machines? - Zyzzle, 28.03.2024, 02:49
- Tyrian 2000 in DOS with sound on PCIe only machines? - Japheth, 28.03.2024, 06:34
- Tyrian 2000 in DOS with sound on PCIe only machines? - RayeR, 28.03.2024, 04:43
- Tyrian 2000 in DOS with sound on PCIe only machines? - Japheth, 28.03.2024, 06:10
- Tyrian 2000 in DOS with sound on PCIe only machines? - RayeR, 29.03.2024, 20:20
- VSBHDA 1.5 pre - RayeR, 15.05.2024, 07:06
- VSBHDA v1.4 (final) has been released - Japheth, 20.04.2024, 10:41
- VSBHDA v1.4 (final) has been released - rr, 20.04.2024, 20:07
- VSBHDA v1.4 (final) has been released - Zyzzle, 21.04.2024, 01:56
- VSBHDA v1.4 (final) has been released - Japheth, 21.04.2024, 10:39
- VSBHDA v1.4 (final) has been released - Zyzzle, 22.04.2024, 13:31
- VSBHDA v1.4 (final) has been released - rr, 22.04.2024, 20:07
- VSBHDA v1.4 (final) has been released - 0ffer, 28.04.2024, 08:57
- VSBHDA v1.4 (final) has been released - Rugxulo, 28.04.2024, 11:16
- VSBHDA v1.4 (final) has been released - 0ffer, 28.04.2024, 12:35
- Windows for Workgroups 3.11, FreeDOS, MS DOS 8, HIMEM etc. - mceric, 28.04.2024, 16:41
- Windows for Workgroups 3.11, FreeDOS, MS DOS 8, HIMEM etc. - 0ffer, 29.04.2024, 00:57
- VSBHDA v1.4 (final) has been released - roytam, 28.04.2024, 11:43
- VSBHDA v1.4 (final) has been released - 0ffer, 28.04.2024, 12:37
