Introduction, a return to DOS (User Introductions)
> > That is correct, it has that internal memory storage card. I happen to
> have
> > Linux on that, so am booting the FreeDOS from a USB.
> Why don't you have a dual-boot system set up, where you wouldn't need to
> boot from USB but just select which OS to boot from a menu? There are both
> free and commercial versions of software to do that.
Yes, I could definitely set up a multiboot system. But, I am experimenting with many of things, so not ready to commit to permanent partitions on the Zimaboard yet. I'd rather keep it flexible and uncommitted for now.
~Bill
- Introduction, a return to DOS - WDA0208, 06.03.2025, 04:26 (User Introductions)
- Introduction, a return to DOS - kerravon, 12.03.2025, 21:45
- Introduction, a return to DOS - WDA0208, 13.03.2025, 00:44
- Introduction, a return to DOS - kerravon, 13.03.2025, 06:46
- Introduction, a return to DOS - WDA0208, 13.03.2025, 15:49
- Introduction, a return to DOS - bretjohn, 14.03.2025, 16:18
- Introduction, a return to DOS - WDA0208, 14.03.2025, 23:17
