Compiling DJGPP code. (Developers)
> > 2. Can I use DJGPP to build this under XP or do I need a "real" dos? How
> > doable is this?
> If you have had asked "Can I use DJGPP to build this under 'real' DOS or
> do I need XP?", perhaps your question wouldn't have had so comical
> overtones.
The point is more that my dos/win9x system is slow (233MHz), and has networking problems (I have to reboot to get stuff on it via Linux)
If it would be doable on XP, I could run it on a heavier system. Which is nice for compiling larger bodies of code. But maybe I should indeed mail the current builders first.
- Compiling DJGPP code. - marcov, 12.08.2009, 09:15 (Developers)
- Compiling DJGPP code. - Rugxulo, 12.08.2009, 17:36
- Compiling DJGPP code. - Khusraw, 12.08.2009, 23:10
- Compiling DJGPP code. - marcov, 13.08.2009, 14:02
- Compiling DJGPP code. - Khusraw, 14.08.2009, 07:42
- Compiling DJGPP code (GDB) - Rugxulo, 11.09.2009, 06:48
