DUGL Player 0.4 alpha 2 (Theora/OGG) (Announce)
> Quite possibly. :) There is no visible indication as to whether
> smoothing is on or off.
Yes you are right, I have to add a configuration dialog or at least display shortly "smoothing on" or "smoothing off". Currently you can check if smooth is enabled or not on the about dialog (Smoothing(ON or OFF)).
> Got it. Ran it.
> On one of my testing .OGG files, the difference seemed to be at most 1
> additional frame/sec.
> On the other, it went up by an extra 20 fps ! With or without smoothing,
> it ran at 35 fps.
> Remarkable !
> It seems the effect depends on the quality of the .OGG file. At low
> frame-rate, there is not a lot of improvement available, but with high
> frame-rates there is a noticeable improvement.
I guess, on the case where there isn't a true difference with/without vesamtrrr, that the true bottle-neck is the ogg decoding/YUV2RGB conversion.
In this case you can increase the fps by enabling FAST YUV2RGB (F2) but video quality will be low.
- DUGL Player 0.4 alpha (Theora/OGG) - FFK, 17.10.2009, 15:18 (Announce)
- DUGL Player 0.4 alpha (Theora/OGG) - flox, 17.10.2009, 18:51
- DUGL Player 0.4 alpha (Theora/OGG) - Laaca, 18.10.2009, 15:35
- DUGL Player 0.4 alpha (Theora/OGG) - FFK, 18.10.2009, 16:41
- DUGL Player 0.4 alpha (Theora/OGG) - flox, 18.10.2009, 18:59
- DUGL Player 0.4 alpha (Theora/OGG) - Rugxulo, 19.10.2009, 10:36
- DUGL Player 0.4 alpha (Theora/OGG) - FFK, 19.10.2009, 23:21
- DUGL Player 0.4 alpha (Theora/OGG) - DOS386, 21.10.2009, 01:02
- DUGL Player 0.4 alpha (Theora/OGG) - FFK, 22.10.2009, 21:43
- DUGL Player 0.4 alpha (Theora/OGG) - ron, 22.10.2009, 23:16
- DUGL Player 0.4 alpha (Theora/OGG) - ron, 23.10.2009, 00:18
- DUGL Player 0.4 alpha (Theora/OGG) - FFK, 23.10.2009, 00:44
- DUGL Player 0.4 alpha (Theora/OGG) - ron, 23.10.2009, 02:39
- DUGL Player 0.4 alpha (Theora/OGG) - DOS386, 23.10.2009, 05:40
- DUGL Player 0.4 alpha 2 (Theora/OGG) - FFK, 27.10.2009, 01:49
- DUGL Player 0.4 alpha 2 (Theora/OGG) - ron, 27.10.2009, 23:08
- DUGL Player 0.4 alpha 2 (Theora/OGG) - FFK, 28.10.2009, 01:04
- DUGL Player 0.4 alpha 2 (Theora/OGG) - ron, 28.10.2009, 02:18
- DUGL Player 0.4 alpha 2 (Theora/OGG) - FFK, 28.10.2009, 09:37
- DUGL Player 0.4 alpha 2 (Theora/OGG) - RayeR, 28.10.2009, 21:59
- DUGL Player 0.4 alpha 2 (Theora/OGG) - FFK, 29.10.2009, 00:04
- DUGL Player 0.4 alpha 2 (Theora/OGG) - ron, 28.10.2009, 22:27
- DUGL Player 0.4 alpha 2 (Theora/OGG) - FFK, 29.10.2009, 00:15
- DUGL Player 0.4 alpha 2 (Theora/OGG) - DOS386, 30.10.2009, 06:37
- DUGL Player 0.4 alpha 2 (Theora/OGG) - FFK, 31.10.2009, 11:16
- DUGL Player 0.4 alpha 3 - FFK, 12.02.2010, 01:30
- DUGL Player 0.4 alpha 3 - DOS386, 14.02.2010, 08:54
- This time the "insight" will work with "DUCKS.OGV" - DOS386, 15.02.2010, 08:52
- DUGL PLayer 0.4 alpha4 - FFK, 20.02.2010, 01:01
- DUGL PLayer 0.4 alpha4 - DOS386, 21.02.2010, 14:14
- DUGL PLayer 0.4 alpha4 - FFK, 21.02.2010, 17:23
- DUGL PLayer 0.4 alpha4 - DOS386, 22.02.2010, 08:29
- DUGL Player 0.4 alpha 3 - Zyzzle, 17.02.2010, 01:53
- DUGL Player 0.4 alpha 3 - FFK, 17.02.2010, 12:19
- DUGL Player 0.4 alpha 3 - DOS386, 18.02.2010, 09:02
