| david 17.10.2013, 16:58 |
links.exe (Developers) |
Hi, |
| ron Australia, 18.10.2013, 01:51 (edited by ron, 18.10.2013, 02:05) @ david |
links.exe |
> I have yust uploaded links.exe compiled with obsolete Dellorie svgalib --- |
| iw2evk Magenta (Italy), 18.10.2013, 08:22 @ ron |
links.exe |
Hi, |
| marcov 20.10.2013, 21:18 @ ron |
links.exe |
> It also generated a large file GMON.OUT |
| david 24.10.2013, 11:55 @ david |
links.exe |
Hi, |
| andrea936 24.10.2013, 23:22 @ david |
links.exe |
thanks to David |
| david 25.10.2013, 08:45 @ andrea936 |
links.exe |
> It seems the problem remains about java script in dos. |
| ron Australia, 25.10.2013, 09:25 @ david |
links.exe |
> I think that links generally doesn`t support javascr***! --- |
| david 25.10.2013, 14:01 @ ron |
links.exe |
> However, I do have a Linux build of Links with SSL and a minimal |
| iw2evk Magenta (Italy), 25.10.2013, 20:46 @ david |
links.exe |
| ron Australia, 25.10.2013, 00:42 @ david |
links.exe |
> Roberto and others, --- |
| Doug 25.10.2013, 08:28 @ ron |
links.exe |
> Could not get it to work in graphics mode. |
| david 25.10.2013, 08:42 @ Doug |
links.exe |
> Anyway, i do have a question. I want to use Links as a local .HTM-file |
| ron Australia, 25.10.2013, 09:06 (edited by ron, 25.10.2013, 22:16) @ Doug |
links.exe |
> Could not get it to work in graphics mode. --- |
| ron Australia, 25.10.2013, 22:26 @ ron |
links.exe |
FWIW: This is the .bat file I use to run Links in MSDOS 6.20: --- |
| iw2evk Magenta (Italy), 26.10.2013, 13:42 @ ron |
links.exe |
Hi all, |
| ron Australia, 27.10.2013, 01:11 @ iw2evk |
links.exe |
> For Dave and Ron : i've see in glinks.bat a" set randfile" command referred --- |
| Doug 28.10.2013, 23:45 @ ron |
links.exe |
> try file://c:/somedir/afile.htm |
| ron Australia, 30.10.2013, 01:49 @ Doug |
links.exe |
> What i'm trying to do is use Links as an external viewer from my TUI shell, --- |
| Doug 30.10.2013, 04:57 @ ron |
links.exe |
Ron - Hey! Thanks for the encouragement... but "/" doesn't even work from the command line! So it's not just my shell program. |
| ron Australia, 30.10.2013, 06:57 @ Doug |
links.exe |
Doug, --- |
| david 23.11.2013, 12:38 @ david |
links.exe |
Hi, |
Thread view
