| ecm Düsseldorf, Germany, 01.04.2023, 09:09 |
A question about the new /J switch for TSRs (Developers) |
I have written about how I want to extend the /J switch of my TSRs. Prior to this, /J was just a switch to disable allocation of a DOS UMB. The change is that if /J is immediately followed by --- |
| bretjohn Rio Rancho, NM, 02.04.2023, 06:13 @ ecm |
A question about the new /J switch for TSRs |
I'm confused about exactly what you're trying to accomplish. It kind of looks like you're trying to have all your TSRs use the same switches, and want to use the /J as sort of an "entry point" into memory related functions instead of having several different switches? |
| ecm Düsseldorf, Germany, 02.04.2023, 08:50 @ bretjohn |
> I'm confused about exactly what you're trying to accomplish. It kind of --- |
| bretjohn Rio Rancho, NM, 03.04.2023, 06:27 @ ecm |
> Don't know what you mean by "entry point" but I certainly don't want to |
| ecm Düsseldorf, Germany, 04.04.2023, 14:12 @ bretjohn |
> > Don't know what you mean by "entry point" but I certainly don't want to --- |
Thread view
