07.03.2025, 23:01
What's the 86 DOS system with the smallest LMA footprint? (Announce)
I compared MS-DOS v5, FreeDOS, Enhanced DR-DOS, and the lMS-DOS based lDOS in this question and answer. All using the same dosemu2 and FreeCOM. https://retrocomputing.stackexchange.com/questions...em-with-the-smallest-low-memory-area-footprint/
07.03.2025, 23:31
I only used MSDOS (mostly 6.x after it was out) in the day, but using 4dos command interpreter instead of command.com freed up more memory.
boeckmann
Aachen, Germany,
10.03.2025, 13:41
Did you also investigate the situation without UMBs and / or the HMA being available?
10.03.2025, 14:08
@ boeckmann
> available?
No, not yet. I'm intending to test the lDOS kernel with less memory available at a later point, regarding the question in https://github.com/SvarDOS/edrdos/issues/136
23493 Postings in 2218 Threads, 408 registered users (0 online)
