CRITICAL OFF-by-32-KiB-BUG (Users)
> OK, so to sumarize test conditions:
> * problem is in decompression routine
Right ... there is another problem (also rare and random) with compression too (Page Fault in Ring0) 2011-07-03
> * file must be password protected
Possibly (not yet observed without)
> * file must be quite large
Right
> * decompression must be done many times until error occur
Right
> * bug is not dependent on file content or password (length)?
Most likely. AFAIK 7-ZIP does 2^19 of SHA256 hashes anyway, so any (length) PWD ends up in a 256-bit key
> To test do some repeated decompression, md5sum, comparison...
Right ... like repeatedly throw 4 dices and wait for (6,6,6,6).
> Did you tried under different OSes?
FreeDOS and EDR-DOS.
- CRITICAL OFF-by-32-KiB-BUG - DOS386, 27.03.2013, 09:10 (Users)
- CRITICAL OFF-by-32-KiB-BUG - RayeR, 28.03.2013, 02:16
- CRITICAL OFF-by-32-KiB-BUG - DOS386, 29.03.2013, 09:26
- CRITICAL OFF-by-32-KiB-BUG - RayeR, 29.03.2013, 11:02
- CRITICAL OFF-by-32-KiB-BUG - DOS386, 29.03.2013, 11:19
- CRITICAL OFF-by-32-KiB-BUG (threads) - DOS386, 31.03.2013, 17:42
- CRITICAL OFF-by-32-KiB-BUG (threads) - RayeR, 03.04.2013, 12:35
- CRITICAL OFF-by-32-KiB-BUG (threads) - Zyzzle, 04.04.2013, 04:17
- CRITICAL OFF-by-32-KiB-BUG (threads) - RayeR, 04.04.2013, 13:51
- CRITICAL OFF-by-32-KiB-BUG (threads) - DOS386, 04.04.2013, 04:37
- CRITICAL OFF-by-32-KiB-BUG - Rugxulo, 05.04.2013, 19:15
- CRITICAL OFF-by-32-KiB-BUG | Eric | LZMA2 - DOS386, 10.04.2013, 12:00
