preliminary Jemm v5.68 (includes XDMA32 with SATA support) (Announce)
posted by Japheth Homepage, Germany (South), 26.11.2007, 14:01
> When you enabled SATA support do you think if also ITE8211 IDE controller
> will work? With Jack's help I tried to replace PCI subclass code from 01h
> to 80h and then ITE controller was detected, even busmaster IO base was
> reader OK from PCI registers but it hanged.
At least there is a chance if your BIOS supports EDD-3.0, because then the driver can get the PCI device+subclass by BIOS call int 13h, ah=48h.
Thread locked
22762 Postings in 2122 Threads, 402 registered users (0 online)
