ANSI escapes for input (Developers)
posted by bocke, 09.02.2024, 20:10
> I am already using that - for OUTPUT. And as you noted, I need to go to
> NTVDM. But I still want to run 32-bit software. Win32 executables. And
> hence - HX.
Well, to me it sounds like all this could be done much simpler. Like, running it in pure DOS or even DOSEmu on Linux should do the work in much simpler way (and it's likely to have a builtin debugger).
But, I don't mind. It's your project, so you do you. :)
> And for INPUT, I needed to modify my C library (PDPCLIB) to generate the
> appropriate ANSI escapes for cursor movement (that other application
> software expects).
Cool. I can stand behind that. :)
> I am interested in 16-bit software too (as you apparently are too if you
> are still running MSDOS). So OS/2 1.x is an important part of that.
You want to implement 16-bit OS/2 runtime on PDOS/386?
Well, if that's what your goal is, take a look at the following projects:
https://github.com/icculus/2ine
https://github.com/osfree-project
Or you just want to have ability to run 16-bit OS/2 apps on your development machine?
> And also I'm the one who is doing any debugging. I might be the only one
> using it too. :-)
Well, have fun. :P
22752 Postings in 2119 Threads, 402 registered users (0 online)
