Really serious of technical issue? (Miscellaneous)
> Sorry but I saw most of the discussion not necessary.
> Some guys always insist UPX not safe, then you can unpack it, delete UPX
> from your hard disk and feeling happy.
I like this packer, but I have never seen DOS SYS drivers packed with this packer before drivers of Jack... His drivers are small enough (moreover, tiny) even without UPX, which is very actual for "heavy" DJGPP executables or WIN32 PE files.
> If you think UIDE/XMGR have problem after packing, don't use it and delete
> it from your hard disk, why waste time typing long long message for
If I see such a problem, I'll simply assemble non-packed version from ASM sources (MASM 5.10 or Pravetz-16 386 ASM from Lucho).
> When everyone have no UIDE to use, those guys are happy?
I see that you have removed drivers.zip from your site. That's a pity :( - those forum flamewars aren't really important. E.g. MS Windows is often called "must die" or "crap" but Bill Gates releases it year to year...
P.S. I perfectly understand that modern DOS is made of hacks itself, and UPX in SYS file isn't the most dangerous :).
- Really serious of technical issue? - johnsonlam, 09.11.2007, 18:53 (Miscellaneous)
- Really serious of technical issue? - lucho, 09.11.2007, 19:20
- Really serious of technical issue? - avoskov, 09.11.2007, 19:43
- Really serious of technical issue? - Rugxulo, 10.11.2007, 06:33
- No Diskette Issues. - Jack R. Ellis, 10.11.2007, 07:06
- Really serious of technical issue? - sol, 09.11.2007, 20:20
- Really serious of technical issue? - Khusraw, 09.11.2007, 23:46
- Really serious of technical issue? - sol, 10.11.2007, 02:57
- Really serious of technical issue? - Steve, 10.11.2007, 03:00
- Greetings! - Jack, 10.11.2007, 10:09
- English language - avoskov, 10.11.2007, 11:25
- English language - Jack, 10.11.2007, 11:33
- Greetings! - Steve, 10.11.2007, 12:16
- Right Back Atcha, My Boy! - Jack, 10.11.2007, 12:33
- Right Back Atcha, My Boy! - Steve, 10.11.2007, 13:22
- Call for censorship - lucho, 10.11.2007, 14:07
- Call for censorship - Steve, 10.11.2007, 14:14
- Call for censorship - lucho, 10.11.2007, 14:33
- Call for censorship - Steve, 10.11.2007, 15:08
- Call for censorship - lucho, 10.11.2007, 15:17
- Call for censorship - Steve, 10.11.2007, 15:36
- Call for censorship - Steve, 11.11.2007, 00:32
- Really serious of technical issue? - Khusraw, 10.11.2007, 11:15
