about to fix the "final" doslfn bug (Announce)
posted by Richard, 09.04.2022, 06:15
> For FreeDOS / FreeCOM, you need "set DIRCMD=/lfn" and "lfnfor on" and
> "lfnfor complete on", IIRC. (DR-DOS 7.03's shell also supported LFNs ... if
> enabled by third-party driver.)
Thanks for information.
in my FreeDOS RC5 FDauto.bat I inserted the following lines
c:\FreeDOS\BIN\doslfnms.com
set DIRCMD=/lfn
lfnfor on
lfnfor complete on
and it appears to work for me (i.e. both 8.3 and long file name simultaneously shown when DIR)
Question - because I am using doslfnms.com (instead of doslfn.com) should all "lfn" be replaced by "lfnms" in the last 3 lines (of the 4 lines of code shown above) to reflect the long filename program being used?
> But the FreeDOS kernel doesn't support bigger than 2 GB files anyways.
For my test just now, I only worked with 32K files (instead of 1 Gi file which takes about 30 minutes to load from my usb stick). For interest, it only takes about 1 second to copy FAT32 RAM to FAT32 RAM a 1 Gi file. I do not understand the problem with 4 GiB files when using FreeDOS RC5.
I copied (using RC5) the generated 4 Gi file (in FAT32 RAM) to my usb stick (it took about 2+ hours to do so) and ended up with a 4Gi file on the usb stick. Using a HEX editor (in windows) the 4 Gi appears to be OK EXCEPT for the very first byte (was changed to x1A). I did read somewhere that FAT32 allows files to be 4G-1byte (so I will keep that in mind).
Now that the LFN(ms) appears to work for me - I will try extreme testing with LFN's in FAT32.
The only reason why I tried the old lfn program was that I did not have the longer filenames displayed with doslfnms.com (which seems to be resolved by the four code lines above).
Many thanks
22654 Postings in 2111 Threads, 402 registered users, 579 users online (0 registered, 579 guests)
